Hi..
I am unable to place a footer, as under add element, there is no footer, please kindly assist. https://bitfinsider.com/
Also for this other tabs, how do I sort base on article release? as all the other tabs look the same.
https://bitfinsider.com/category/news/
Please kindly assist
Unable to pull post even though I have one post, and unable to set footer. Please kindly assist
<quote>Also for this other tabs, how do I sort base on article release? as all the other tabs look the same.
https://bitfinsider.com/category/news/</quote>
I’ve solved this by using loop post 1, may I know the difference between loop post 1 and loop post 2 and also flex block 4? Thank you.
For screenshot 1 – https://ibb.co/2098R53
How do I remove the logo at the bottom and removing about us, follow us and the social links.
Also, there is the footer Contact us and Privacy Policy on the mobile site, but it is not appearing on the PC h5 site.
For screenshot 2 – https://ibb.co/wscYSrn
How do I change the logo at the top of the header?
For screenshot 3 – https://ibb.co/W5y6sM6
How do I insert the social links? and can I remove the join / SIGNUP and replace with a subscribe to our mailing list instead?
Thank you
This reply was modified 4 years by
bitfinsider.
Please edit the homepage with the TagDiv Composer, access Website Manager and check if the header and footer are there and it is not selected “No footer”. Check in the Dashboard -> Cloud Templates and see if you have the footer template. If not, then please install a footer template from the Cloud Library or build it from scratch by uploading a blank template.
For the category page, you can add a flex block with filter Category: Current category -> https://forum.tagdiv.com/flex-block-settings-guide/ The posts from that category will display.
Let the offset field empty with no space, no value and see the results: https://www.screencast.com/t/peVbVmUDE. For more information about offset feature, please check this tutorial: https://forum.tagdiv.com/offset-feature/.
Check this topic to see the difference: https://forum.tagdiv.com/topic/location-of-specific-blocks-to-edit/
We have 3 options of mobile versions that you can use:
1. Responsive version: A responsive version of your website is looking similar like on desktop, edit the page with TagDiv Composer, click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB ; there you can see your mobile version and you can edit the elements there or adjust them to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
3. Mobile theme plugin: The Mobile Theme is a performance optimized theme included in the Newspaper main theme and it loads only for mobile devices. It comes with its own templates/design for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout. For more details, please take a look here: https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/
A full explanation you can find here: https://www.youtube.com/watch?v=SpGkOnJeNZY
You can choose to use which one is more affordable and useful for you.
Note: If you want to use version 1 or 2, then you need to deactivate the Mobile theme plugin and see the results.
From what I can see, you use the Mobile theme plugin and there are only some settings in the theme panel -> Mobile theme for customization.
Some texts can be translated from Newspaper -> Theme panel -> Translations -> Translations: https://prnt.sc/zSmXIgSMCyCj
That logo you’ve set up in the theme panel, you can change it and delete it from there.
Social media icons can be disabled/enabled by filling the fields Newspaper -> Theme panel -> Social Networks with the unique URL.
You can delete the join / SIGNUP from here: https://prnt.sc/O96Ni2YaFjJ1
Unfortunately, you can not add other elements there.
Dear Bettina,
Thank you for the prompt reply, let me work it out and get back to you!
Many thanks
Dear Bettina,
I’m still having some issues.
https://ibb.co/2098R53 – Regarding About Us, how do I change it? please provide the direct steps as the screenshot you provided was not full and I couldn’t find it.
https://ibb.co/qNQRPsd – how do I change the CG logo on top? I’ve tried but unable.
https://ibb.co/1Tc5psG – what is the text beside the date suppose to be? I’m unable to change the font colour, and what does the 0 represent on the right side? Can i remove it?
https://ibb.co/d5WbQXm – My footer on other pages are different from my home page, how do I set it to follow the home page?
https://ibb.co/cvCPnBM – The follow on : social links cant be seen on chrome browser, but on brave browser it is able to be displayed. what is the issue here?
please assist me Bettina, Thank you
1. It can be found here: https://prnt.sc/zSmXIgSMCyCj . Insert a space in the right side.
2. I can not see it on your website.
3. It should be the category. This element seems to be a flex block. Please check this guide and find out how you can edit the elements there: https://forum.tagdiv.com/flex-block-settings-guide/ Font color settings are in the Style tab of Flex block element. You can remove that 0 from here: https://prnt.sc/kblTZMEOHfOF
4. Make it global from Dashboard -> Cloud Templates.
5. I’ve checked your website and it is working well. Please delete the cache from your browser, uninstall the cache plugin that you use and try again in an incognito window.
Hi all,
can someone help me with the enquiries please? Thank you
