To improve web performance, I installed Litespeed Cache Plugin and recognized that my web became even slower than that before, also appeared error of loading Homepage as mobile theme instead of desktop theme for Ipad device. Is Newspaper theme compatible with Litespeed Cache plugin? If so, why does it come up with such errors (after uninstalling Litespeed cache plugin, it is back normal) and how to fix this?
In the other case, does WP Super Cache plugin work well? What is your recommendations?
Wp super cache is the tested and recommended cache plugin to use with our theme: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Hi Bogdan,
I am facing same issue and my site is taking 3 mins to load after I enabled super cache, I even contacted host and they said there is no issue from their side. I am using php version 7.1 that will be issue?
This reply was modified 9 years by
yash.
No, Php 7.1 should not be an issue. Please check your wp super cache settings and only use these entries: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Thanks,
Bogdan B
When I test my site: http://daotrangtuphat.com/ from https://tools.pingdom.com/, it indicates the slow loading issue is because of Newspaper theme ‘http://daotrangtuphat.com/wp-content/themes/Newspaper/style.css?ver=8.0’.
So, any recommendations to deal with it, please!
For page speed optimization you will have follow the links below:
Please follow this guide: https://forum.tagdiv.com/how-to-make-the-site-faster/
Please also read this topic: https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
And another helpful topic:
https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
I hope this helps.
