Website load speed.
Hi everyone.
I hope everyone already checked the changes in Google PageSpeed Insights and found that now the theme gets 4-5 score without modifications. Before those Google changes I had 70 scores.
I tried to change it, installed cache as recommended, mod_pagespeed server, plugin td-speed-booster and made all modifications that I have found including the official ones.
In conclusion I got 40-50 score for PC and 30-40 for mobile.
I case you switch to mobile version of the theme the speed booster plugin stops working and the score goes more lower to 20.
What changes the team plan to do to solve that issue?
When it will be solved?
What ideas do you have to make the theme works again 70-80 score. Better for mobile devices.
Please notice that the speed of your website depends on how well your site is optimized.
Notice that is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Also, notice that we have a speed optimization tutorial but this is addressed only to advanced users. So, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/
There are many optimization guides provided by our users here in the forum, some made by us, you could check some of them
https://forum.tagdiv.com/cache-plugin-install-and-configure/
https://forum.tagdiv.com/how-to-make-the-site-faster/
https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
https://forum.tagdiv.com/cloudflare-cdn/
https://forum.tagdiv.com/topic/theme-causing-high-cpu-usage-2/
https://forum.tagdiv.com/topic/sql-querys-high-cpu/
https://forum.tagdiv.com/topic/newspaper-theme-slow-to-respond/
https://premium.wpmudev.org/blog/optimizing-your-wordpress-database-a-complete-guide/
https://underconstructionpage.com/optimize-wordpress-database/
https://crunchify.com/better-optimize-wordpress-database-all-in-one-guide/
