Cancel in post Breadcrumbs.
You can check our documentation for smart list from here -> https://forum.tagdiv.com/smart-lists/ there are few smart list that can display ads too and these are set in them panel -> https://i.imgur.com/a1CZRNg.png
What is the difference between article and post? this is the same thing (article and post), the difference comes when you say “post template”, this is the design that will apply on posts/articles. So the post template style is referring to post layout, the ads will be add on the post template and the article ads is referring to ads that will be displaying inside the post/article ( https://i.imgur.com/kzfiH6p.png ).
Article ads -> https://forum.tagdiv.com/article-ads/
Post template ads -> https://forum.tagdiv.com/post-template-ads/
Hope this will help you to understand better our theme.
Hello calin, I have a potential client with a decoration and design furniture store, I want to use another license for this newspaper but I have not seen a template or theme for that business, which deserves recommendations.
This depend on how you like to look, for example you can use this demo -> https://demo.tagdiv.com/newspaper_spa/ or you can use this one -> https://demo.tagdiv.com/newspaper_law_firm/lets-connect/ or you can use a pro demo https://demo.tagdiv.com/newspaper_classic_pro/ or https://demo.tagdiv.com/newspaper_royal_pub_pro/ all you need to know is how your client will link to be the layout of website.
Hello calin, is there a module in the template or newspaper x theme for a shopping cart or is it separate, which one would you recommend?
I have a question in the mobile version, the upload button does not appear until the beginning, do I have to activate it to exit?
Our theme do not has a template for a shopping cart, but you can achieve this using the woocommerce plugin -> https://docs.woocommerce.com/document/woocommerce-shortcodes/
“upload button does not appear until the beginning” unfortunately I do not know on what button are you referring, please provide some screenshots or a link where I can inspect it.
Hi Calin, thanks for the help of the shopping cart, a bit complex but we will see how I do it.
I attach what is (td-scroll-up td-scroll-up-visible) so that you go that comes out in PC browsers and not in mobiles, before yes.
desk
mobile
mobile formerly
  • This reply was modified 6 years by ludyma.
Yes, by default the button for back to to is hidden on mobile device, but you can display it using this custom css:
.td-scroll-up {
display: block;
The code need to be set in theme panel> custom code> adventure css> phone.
Hope this will help you!
Hi calin, Thanks for your help … I learned a lot with you.
Look I went to the website ryte.com to rate my website and there is one of many that I don’t know why it doesn’t load, it’s the description of the home page, I attach everything I’ve done.
ryte
WP
seo
the other problem is that for example the Sitemap.xml does not load me even having it in the Robots.txt and the Google Analytics says that neither and where are you telling me they have to go, I attach screenshots.
ryte-2
google
wp-2
Unfortunately we do not have experience with ryte.com platform, therefore we do not know exactly how this is working and how is reading the settings from website, sorry!
Please make sure that you are using only the schema from Yoast SEO -> https://i.imgur.com/OG2reAd.png in this way you can prevent the problems with schema.
For setting the sitemap you can check these guides:
-> https://www.wpbeginner.com/wp-tutorials/how-to-optimize-your-wordpress-robots-txt-for-seo/
-> https://wordpress.org/support/topic/sitemap-in-robots-txt/
-> https://yoast.com/wordpress-robots-txt-example/
-> https://yoast.com/ultimate-guide-robots-txt/
How to choose the right focus keyword -> https://yoast.com/focus-keyword/#utm_source=yoast-seo&utm_medium=software&utm_term=focus-keyphrase-qm&utm_content=content-analysis&utm_campaign=wordpress-general&php_version=7.3&platform=wordpress&platform_version=5.4.2&software=free&software_version=14.3&days_active=2-5
Also I see that the code for Google analytics is set well it should work.
Hello Calin, I have seen that in many websites the comments section of the photo is shaded, as I show you in the screenshot, is there a way to do it here?
shadow
The other thing is that I see that there are social networks icons of google news, I have not managed how to implement it or do I have to create it from 0 as a new class? attached catch.
social
Unfortunately using our theme there is no option to display the “comments section of the photo is shaded” I think that it can be achieve with some extra code and custom work.
Also the socials share are different and are look different from the theme to theme, for the moment we have only these social share -> https://i.imgur.com/urCPQJ9.png for the moment if you need other social share the only way is to use some extra plugins.
Hi Calin.
I am desperate, I have read and documented everywhere and I have not succeeded, the problem of the highlighted image, I do not get it on google news, nor in the feed, I do not know what to do.
Attached screenshots of the problem, I hope you guide me.
facebook
feed reader
funtions.php
newscaribe.com/feed
google news
If you are referring to featured image that need to be display when you share a post on Facebook, then you can use our guide from here -> https://forum.tagdiv.com/facebook-share/ use yoast seo.
Also make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
Hi Calin,
I have done everything that is most recommended and nothing, by no means load, what a problem …. I attach test of the web of the Facebook tutorial and see what it shows.
facebook of developers
HI,
If you want you can send us an email at contact@tagdiv.com and provide admin login. I will take a look. Include a link to this topic in the email and make sure that you make a full backup to your website.
Hi Calin, I need your knowledge, it turns out that if I integrate a video and mark it as video the entry as I show you in screenshot 1. On the web it comes out off-center and cropped, there is a way to zoom in and see it centered screenshot 2.
If I integrate it as video by url screenshot 3. in the web it comes out centered but small as shown screenshot 4. in what way can the parameters be changed in that case.
screenshot 1
screenshot 2
screenshot 3
screenshot 4
If you set the video as featured video then the video should be display on full width content, but as I can see in your screenshots, you are using a small video, that is under the post content width, this can be centered using custom css, if you need help with this, please provide me a link to that post with video.
I would appreciate your help with the css since I do not master it.
video
Please try this custom css -> https://i.imgur.com/MXtj4em.png
.single video {
width: 100%;
The code need to be set in theme panel> custom code> custom css.
Hope it will help you!
Than you!
Hello calin, I see in many pages, that they have a kind of plugin or witged like the one that I show you in the posts, how can I search for one or if the topic has one that does, it relates news in the same post or phrases, words.
web
Unfortunately I do not know exactly to witch “plugin or widget” are you referring, I cheeked the link that you provide and I seen in it a newsletter, ads and a normal post.
I need some more information and some screenshot about the elements that you are referring, in this way I can provide an answer.
Hi calin, sorry, I’m missing the screenshot, there is the witged mark that makes you relate news in the same entry, such as READ or MAY INTEREST, what it does for what I see is create news link related to the entry according to the words , I attach a screenshot.
screenshot
web
I see now, unfortunately our theme do not has this option, but I think that it can be achieve manually, when you write a post, you can set the “Leer” with a h2 or 3 and you can set the post title that you want to be inside the article with a link on it, indeed this method will take some time to use it and it can be use for the new posts.
Maybe there are some plugins that can insert in the post content other related posts, something like this plugin -> https://wordpress.org/plugins/intelly-related-posts/
Hi Calin, it turns out that I want to change the drawer graphics when there is no outstanding photo, as in (photo 1) In this photo or capture, you can see that the photo that comes out is the one that brings and not the one that I have put, and also the route, I have changed all the photos and they are not loaded, I do not know the reason, I leave one loaded on the web, so you can look at it and I will attach more capture of the changes.
photo 1
directori rute
Photo 2
web
I think that was only a cache plugin, now is look that the image is apply -> https://i.imgur.com/YaC9vaF.png -> https://i.imgur.com/xE3iVsH.png
Viewing 25 posts - 26 through 50 (of 98 total)
