Help! Upgrade Newspaper 4 to 9 is giving errors
I bought a new license to install the latest version of the newspaper, because I used the 4 yet. I took and updated wordpress to version 5. After installing everything, included the plugins and delete the old version and old plugins, I have the following error when accessing my panel:
Parse error: syntax error, unexpected ‘[‘, expecting ‘)’ in /home/blogsoviagem/webapps/ROOT/site/wp-content/plugins/td-composer/includes/tdc_util.php on line 592
if I delete the td-composer plugin from ftp, I can again open my panel, but when trying to create any page or post, I also have the errors:
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 96 bytes) in /home/blogsoviagem/webapps/ROOT/site/wp-includes/functions.php on line 3151
soviagem/webapps/ROOT/site/wp-content/plugins/td-composer/td-composer.php) [function.fopen]: failed to open stream: No such file or directory in /home/blogsoviagem/webapps/ROOT/site/wp-includes/functions.php on line 4891
Warning: fread() expects parameter 1 to be resource, boolean given in /home/blogsoviagem/webapps/ROOT/site/wp-includes/functions.php on line 4894
Warning: fclose() expects parameter 1 to be resource, boolean given in /home/blogsoviagem/webapps/ROOT/site/wp-includes/functions.php on line 4897
Please helpe me.
I do not know what could be happening. My server support says the problem is with wordpress or theme, not server.
Please make a full backup, delete the theme with plugins ( theme plugins), and make a fresh install.
How to update the theme -> https://forum.tagdiv.com/how-to-update-the-theme-2/
Install via FTP -> https://forum.tagdiv.com/install-via-ftp/
Install via WordPress -> https://forum.tagdiv.com/install-via-wordpress/
Please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
and please increase all requirements that are lower.
If there is still a problem please let us know.
Also remember that version four is a very old theme and version 8+ is an entirely new theme. So you might need to recreate your pages afresh with the tagdiv composer.
Hi, thank you!
I found that the problem was some of my server settings, we increased some parameters and upgraded to php7, and the problems solved! Thanks
