How to Fix H1 Heading (Post Tital)
Hello Newspaper Theme Team
Sir my theme has issue of h1 heading (post title). how to fix it My earlier lcp score was very good but now showing 5.2 seconds. you see the screenshot and tell me how to fix it.
Screen short Check
https://drive.google.com/file/d/1mNpHZOi4PD60NMvTx15-oM2_1hjUu3jX/view?usp=sharing
https://drive.google.com/file/d/1CZsyi2B9cCiPu7QNfyGlUEmWwXvnAPZb/view?usp=sharing
https://drive.google.com/file/d/1sAS-ODBmtRdiXueFt6_5u1IRhEvuW9Z5/view?usp=sharing
If I’m right that is related to the lighthouse chrome https://www.youtube.com/watch?v=VyaHwvPWuZU and pagespeed test. Checking the documentation from here https://i.imgur.com/5tYYzNI.png you can see what can be done to fix the problem.
For a better approach we’ll need to check your website closely, maybe even connect on it, this can be done via email at contact@tagdiv.com
What should I do sir? how to fix it guide PLEASE
What I can suggest is to try to optimize the website, in this way ou can resolve a part of the core web vitals problems. If you want you can try our guide https://forum.tagdiv.com/how-to-make-the-site-faster/
I have sent you the screenshot, I have rounded it up how to fix it
https://drive.google.com/file/d/13lBNMum-z6fX_YQrqu-UICNz_YJ0KsXi/view?usp=sharing
To lower your TTFB time please check the steps from those guides:
-> https://wp-rocket.me/google-core-web-vitals-wordpress/reduce-ttfb-server-response-times/
-> https://searchfacts.com/reduce-ttfb/
Hello sir!
Some error is coming in my site like this you tell me the name of this file or guide me how to fix it.
https://www.rnkhabri.com/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAhYAAAHOAQMAAAD+DNJPAAAAA1BMVEWurq51dlI4AAAAAXRSTlMmkutdmwAAADVJREFUeNrtwQENAAAAwiD7p7bHBwwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAICEA3q4AAGK1CNoAAAAAElFTkSuQmCC
I tried it a lot I didn’t get any solution. please help me AND GUIDE
because my traffic has decreased and ranking is down
My LCP score was good before but now showing 4.7
Help me to solve this 404 error. Which image url is it showing?
https://drive.google.com/file/d/1YnDsWCXcrgmUHSXkw_caqEU3aLuQ3o8A/view?usp=sharing
WAIT FOR REPLY
This https://www.rnkhabri.com/image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAhYAAAHOAQMAAAD+DNJPAAAAA1BMVEWurq51dlI4AAAAAXRSTlMmkutdmwAAADVJREFUeNrtwQENAAAAwiD7p7bHBwwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAICEA3q4AAGK1CNoAAAAAElFTkSuQmCC seems to be related to images that are converted in base 64, it seems that if you access the link, you get 404 -> https://i.imgur.com/I4cYbto.png
I checked your website and now, that image is no longer appearing the console, but you have an error from a plugin -> https://prnt.sc/sXEfM6MX8wNl
Also, I see that you have the LCP problem only on mobile, for this I recommend to try the mobile theme plugin or the mobile page template -> https://www.youtube.com/watch?v=SpGkOnJeNZY
I have same problem in my website, how to fix the H1?
If you are using a standard header, then the H1 will be on logo and titles, when a title is present the logo will no longer have h1.
Now if is a cloud, then you can choose the element that will have the h1 -> https://i.imgur.com/E2B3K8n.png (for example each logo from the website will have h1 also the posts/page titles).
I hope this will help you!
How to activate it is not being assigned. How to remove the one that is not installed in WordPress where it is ticked. check screenshot
https://drive.google.com/file/d/1ioxcmDSwXVTi7KAJlDwhvltcV7nI_IVq/view?usp=sharing
I saw you sent an email; please continue the discussion there.
I am not able to assign. wordpress-607150-2925743.cloudwaysapps.com is active in this. It has to be assigned.
I have uninstalled http://www.rnkhabri.com which is at number two. You assign it wordpress-607150-2925743.cloudwaysapps.com so that I can do something
check screenshot
wait for reply
https://drive.google.com/file/d/1s26qw8NNw2XOrKR5NBlQ6DY_82gmCM3Y/view?usp=sharing
https://drive.google.com/file/d/1_zAShIBWWPIRaNF9YgvpMQxs8wOQreOh/view?usp=sharing
You should check the screenshot and what is the round done in it and how to fix it
https://drive.google.com/file/d/1ld503cdYMJ6voq-SyByiQGnk98LLWK3f/view?usp=sharing
As I said above, please continue the discussion by email, because the email colleague will not check if you have written on the forum, and then there is a possibility that the help to help you solve the problem will be delayed. Also, pagespeed is not covered by support.
How to td Standard pack Unused CSS file remove
Please Help and Solution
Viewing 17 posts - 1 through 17 (of 17 total)
