Perfect, is working, BUT i have another question, that maybe it will be a problem on the future, why the theme is uploading the same instagrams images several times to my media library (repeated images), this will fill my server with images that will not even be used anymore, screenshot- https://nimb.ws/KuaTy9
Hi boris.prado, that is part from the fix that was added, as long as you have the Instagram images in media, those will be delivered from there and the Instagram images will no longer be display as broken images, indeed the problem that remains is that the media size will increase and we want to avoid this. We hope that the coming update to have a better solution then this one.
Thank you for your understating!
Calin, to report that after Jan4, when your developers fix it, just refresh 1 more time, and no more refresh, we have 7 new post that are not refresh on the wordpress site, i also sent the request by email.
Please review it and let me know
I just stop using it, and install a plugin for Instagram
I’m sorry, we do not have any ETA. But, I write in this topic so many times to send us an email, we will take a look to your issue and we will try to resolve it. Let us know and we will gladly assist you as soon as possible.
Thank you for understanding!
Hi, TagDiv our Developers has updated the much awaited version of Newspaper theme with high hopes that, according to your reps, the new update will fix our instagram issue, but have to say with disappointment, that after updating the theme to the latest version, the problem of Instagram stays wherever it was before?
Now, will you guys would say that wait for another update of the theme?
How long will you guys play this annoying game with your clients??????
Unfortunately, we couldn’t add this fix in this update because we need to make sure it is 100 % well tested, so you won’t meet any other issue.
We are sorry for the inconvenience, but we would like to deliver a solution which is well tested because the issue of Instagram require some time.
I’ll keep you updated while we release this fix.
It’s pathetic to know that how well you cover your lies that you told to your customers. You have wasted our 2.5+ months for sorting out this issue and it seems that you guys wouldn’t bother to solve this issue for the next 2.5 years or so.
STOP PLAYING THESE JOKES WITH YOUR CUSTOMERS
I have the same problem. Please, is there any procedure I can try before they release this update?
This reply was modified 4 years by
leandrocastro.
Install a plugin while they fix the problem, im using https://smashballoon.com/instagram-feed/ plugin and is working very well, almost the same like the one of tagdivi.
Is a temporally fix while they fix it.
Hello @great1212,
We’ve done a lot of testing and added a new implementation, so please log out and reconnect, for both Facebook and Instagram platforms.
My colleagues also tried to help you and invited you by email to investigate the issue, but you refused.
Because of this, we have no way of knowing if the problem is due to us or maybe to a plugin you are using (there are various causes, which if we do not know the cause we can not solve).
