installation problems
I cannot get the Newspaper WordPress .zip to install. I am not doing anything any differently than when I have used other templates. It’s like nothing happens. Please help.
First please make sure you are installing the actual theme zip file, not the whole theme package
https://forum.tagdiv.com/whats-included/
The theme file is located inside the full package you download from themeforest
https://www.screencast.com/t/YAstK6bLp
Also make sure the max upload size is not smaller than the theme size
These are the installation guides you can follow
https://forum.tagdiv.com/install-via-wordpress/
https://forum.tagdiv.com/install-via-ftp/
