For Mobile speedtest, using pagespeed the below was found. However the corresponding scripts can not be identified using the functions.php script. Why are these slow. ON the Desktop speed tests im getting speeds of 90+ but mobile its like 20
…vendor/react-dom.min.js?ver=16.6.3(debrecentoday.com)
31 KB
1,230 ms
…tinymce/tinymce.min.js?ver=4800-20180716(debrecentoday.com)
111 KB
1,680 ms
…dist/blocks.min.js?ver=6.0.5(debrecentoday.com)
42 KB
930 ms
…vendor/lodash.min.js?ver=4.17.11(debrecentoday.com)
24 KB
930 ms
…vendor/wp-polyfill.min.js?ver=7.0.0(debrecentoday.com)
30 KB
1,080 ms
…jquery/jquery.js?ver=1.12.4(debrecentoday.com)
33 KB
1,230 ms
None of the mentioned resources are theme related. They are either WP or plugin related resources that are not handled by the theme.
If you want to get top loading speeds please use the following guides:
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
We also recommend this Cloudflare configuration
For speedbooster you can disable the compatibility check like so:
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
