my website speed is too slow I was asked to contac developer theme
my website is too slow I was asked to contac developer theme.
my continually hitting process limit problem.
this answer support email to me :
” There will not be any change if the account is moved to another location. Your site(s) will still load slow as you are continually hitting process limit. You need to optimize your sites by contacting your developer or you’d need to upgrade your account to either semi-dedicated or VPS which offers more resources.
If you need any further assistance, please let us know.
<br />——————————<br />
Albie R.<br />
Support Department, Hawk Host “
hello dev
See the theme docs, tutorial section on tips for optimizing speed. To learn how to optimize wordpress, also test a post with gtmetrix.com
Analysis Error
An error occurred fetching the page: read timeout
There may be a connectivity issue between your server and the GTmetrix test server. Please login to try testing from another test location or try again later.
Please see our FAQ on how to fix this error.
we asked to change this theme,
but we are sure that this theme is good
this opinion came from the hosting support and partner develope,
If you should decide that the theme is not suited for the website, we will be able to provide a refund if requested.
There are many guides here on the forum regarding page speed optimization. Such as these
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
– https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Hopefully you can try some of these suggestions provided by theme users, and get better results in the matter.
Try testing from another location with GTMetrix.com — see the ‘how to’ on that site to change the “test server location” if your country/host blocks them; which is highly unusual except in some countries. In our case, we’re in USA, and the test server we use is in Canada (GT is in Canada hence the default testing from Canada).
I have done various ways.
but this theme is not suitable for us
theme error back
there may be admins who can help solve this problem
I will give access to my wp admin
Hello @dhapenk , the process limit is hitting because of the search bar present in the newspaper theme. I had have been that issue too, i solved it using heartbeat plugin which removed a lot of load from my hosting panel. Apart from that, use Wp-Optimize to make more space in database. Hope it helps. Do check out my Wp Speedify Guide.
Heartbeat plugin- https://wordpress.org/plugins/heartbeat-control/
Wp-Optimize- https://wordpress.org/plugins/wp-optimize/
Or maybe you should consider upgrading the hosting plan, if the current one is limited in such ways that you cannot maintain a proper website functionality. Basic hosting plans have limits that are easily reached
– http://www.wpbeginner.com/wordpress-hosting/
– https://www.wp101.com/best-wordpress-hosting/
