Dear Creators,
I have tried many options in last 2-3 days for improving Google Pagespeed scores – main area is Minify CSS and JS and Caching. I signed-up CloudFlare free / basic plan – but i dont think it is working.
***** Part 1: Minify CSS and JS
I tried following plugins and for last 2-3 days, it is not very much succesful and most of them give FOUC on the site.
Plugins Tested:
1. Autoptimize (If enable HTML then FOUC within seconds, and cannot select any advanced options because FOUC)
I tried to select options to push CSS inline and load into the head – using the advanced options, but homepage breaks.
2. WP Roids (some issue with .htaccess – maybe because of my hosting, but give FOUC) – I have contacted the plugin author already and there is another guy which has Newspaper 7 theme having issue with this plugin.
https://wordpress.org/support/topic/breaking-site-with-newspaper-7-visual-composer/
3. WP Super Minify (i dont know if this did anything – cannot see any changes)
4. Best WordPress Minify – using since today afternoon – Not FOUC yet
Note: Cloudflare Minify option is activated all the time.
Can you please advise which plugin to use – which will not break the CSS and render pages properly. I removed Revolution Slider for now also to improve speed.
This topic was modified 9 years by
oilwire.
Unfortunately there is no minification tool we can guarantee will work .In order to improve your page speed please use this guide: https://forum.tagdiv.com/how-to-make-the-site-faster/
As a note on the speedbooster plugin: https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
If you want to use a cdn server please only use these settings: https://forum.tagdiv.com/cloudflare-cdn/
For cache we recommend: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Hi Bogdan,
I am going through the process step in the guide, i have some limited knowledge in coding but i will try.
I am checking the compatible plugins also, I have some issues with the cache plugin (not allowed), so I am trying to find some answers. Thanks for sharing, this link is useful – http://screencast.com/t/hcjLnOqh4i2.
I am trying to settle with Cache Enabler + Optimus (webP support) for the Cache and Images.
Cloudflare is setup as recommended in the tutorials 🙂
Multumesc, Ciao.
