My site is eNews Park Forest: https://www.enewspf.com
Site is extremely sluggish. I’m using Newspaper with the Magazine Pro “prebuilt” theme.
Might one of my plugins be going to war with Newspaper? I turned off all previously used page builders.
Here’s what I have in plugins right now (long screenshot):
Hello @frodojrr!
Our tested plugins with our theme can be seen here: https://prnt.sc/OnlJ_6PFY6nc
Please make sure that Cloudflare is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/ and you disabled the Rocket Loader.
Check this topic also: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
We recommend using only one cache plugin, the WP Super Cache plugin with this configuration: https://forum.tagdiv.com/cache-plugin-install-and-configure
Hi frodojrr,
This can be caused by more factors.
It can be from the host. It can be from the extra plugins. It can be from external resources.
What I recommend is to make a full backup for your website and after that make some tests using only the necessary plugins.
Make sure that the theme requirements are set https://forum.tagdiv.com/requirements-for-newspaper/ after that try the settings from ours guide https://forum.tagdiv.com/how-to-make-the-site-faster/
I hope this will provide some improvements.
Let us know the results!
