Slow Site Speed After First Activation
Hi team,
I just purchased and installed the theme but it loads very slow. It cannot load at the first try and I have to refresh. And it take around 1 minute to load after the refresh.
I tried to change to another theme and the speed was fast. It seems to be an issue with this theme.
Please advise how to fix it.
Update: My site cannot load now after I reactivated the theme again.
Every theme needs some optimization. Please do not use non-tested plugins with our theme. Our theme was tested with those plugins: https://prnt.sc/ddysTc8qPu19
Make sure that all the requirements are done as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ Set your php version 7.4.
Some starting points to improve your website page speed are here:
https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
https://www.xtechkr.com/optimize-newspaper-theme/
https://forum.tagdiv.com/how-to-make-the-site-faster/
https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
https://developers.google.com/speed/docs/insights/v5/about
https://www.youtube.com/watch?v=tnkVapqhIHc
– Disable the lazy load animation from here: https://www.screencast.com/t/O5pfqQdb and it will increase also the speed of your pages.
Please check the tutorials from those platforms, GT metrix and Google Pagespeed Insights, and I’m sure you can increase the page speed.
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
My question is not to “increase the site speed”. The problem is once the theme is activated right out of the box, my site speed becomes slow and even unable to load. I have not installed fancy plugins neither.
As I did not expect it takes extra effort to avoid the decrease of site speed, I would like to request for a full refund. Please advise the next steps.
The tagdiv Composer plugin is a bigger one with a lot of functions and settings. Our developers tried to improve it more and more, optimize it as much as they could in every update, and also bring in new features. We will try to do our best for this, but it will always need a little bit of separate optimization depending on each website. And, without a doubt, good optimization entails using the tagdiv Composer plugin’s features less.
Would you please advise the steps to arrange the refund?
You can request a refund here: https://themeforest.net/refund_requests/new
