Social counter / and Instagram problem
@Talent10 Please send us an email at contact@tagdiv.com and provide admin login and FTP access. We will take a look. Include a link to this topic in the email.
@mbernloehr
I have tried your Instagram ID after making the modification in the theme file. Everything seems to work as expected
– https://www.screencast.com/t/Gr0WwrwJ
Please double check if you made the modification properly, all the code in that file has to be removed and replaced with this one
– https://www.screencast.com/t/DlwKiSQbtkx
– https://pastebin.com/yrr2DdwB
Then clear all caches,please let us know.
Double checked. All the code is replaced. Deleted the cache and even deactivated WP Super Cache plugin. Doesn’t work.
Thanks you so much.
Big Thansk Bogdan B.
It works for me, here: http://kissfmmedan.com
any update on this coming?
I’ve managed to copy and paste all the instruction you gave me, but it seems somehow the link automated added # (hashtag) to the end of my Instagram ID
for e.g. if my url is instagram.com/dennissuryana, it automatically becomes instagram.com/dennissuryana# how to fix this?
I don’t have any information I could provide you regarding a theme update at the moment. An update would contain exactly the same modifications mentioned in this topic.
@mbernloehr
We could take a look, send us as well an email at contact@tagdiv.com and provide admin login and FTP access.
@DensS
Your Instagram ID seems to work from what I can see
– https://www.screencast.com/t/ytfjaNi5I
It works in both Instagram widget and social sharing counter. That hashtag is added after the user ID in by the social counter plugin, it will not cause any issues.
Hi guys,
Been struggling as well to make it work, but now it does work.
After looking at the code fix, looked like it was using json fields that only an authorized app/user could check since the last IG patch.
in order to make it work, on top of following the code patches explained above, just install another extension like Instagram Feed and setup the authorization part – that is, the one that will allow your wordpress site to access your instagram data. After that, it automagically appears.
Enjoy 🙂
I sorry, but I cant fix problem with instagram.
I go to: wp-content\themes\newspaper\wp_boost -> td_istagram.php -> i dell all code and copy new from here: https://pastebin.com/yrr2DdwB
and I dont have nothing.instagram not have pictures.
pictures
https://ibb.co/dDGUKx
Hello alexfairtex,
Please make sure that you have followed the exact steps to fix this problem and the code has been correctly added in the right section if you want to achieve best theme results. Make this change via FTP way for more accurate. Clear all the caches and check the results.
Sorry, but I do same with:
“Bogdan B., #223486 ,Mar 16, 2018 at 1:10 pm”
Can you check please? (code td_instagram)
https://ibb.co/jgSXpx
https://ibb.co/dHcnNH
https://ibb.co/b9bE2H
https://ibb.co/bH5Vbc
https://ibb.co/jdSyUx
its “td_social”:
https://ibb.co/fbaGzx
result:
https://ibb.co/fAUn6c
https://ibb.co/kuRpKx
For me so important this widget, can you check please?
Hi!
I made changes as you wrote. Instagram works perfectly. But social media counter doesn’t count lies från my FB-56 likes and google-1 like. Why is that?
Edward,
I followed your instructions and updated the files but my IG feed is still not displaying. I went through several times and tried it with no success.
@lchfdieta
, please notice that the problem with Facebook does not come from our theme but only from the Facebook stuff, sorry! Try to generate another Facebook App Key, clear all the caches and check the results.
@sasquatters
, most likely, you do not do the right thing because if you will check the above feedbacks, many of our customers which has this problem have success using our solution, sorry! Try it again with more attention and let us know how it goes! After these changes were made, clear all the caches and check the results.
This is really a cache and google chrome.
thank you for help!
It must have just taken a while to update because I didn’t change anything and now today it is working. Thanks for the temp fix everyone.
I tried the fix and all my posts lost it’s featured images.
https://ibb.co/hQD4px
**UPDATE:
I just reverted back to previous code, will wait for official fix later.
  • This reply was modified 8 years by Resple. Reason: added info
Hello Resple,
Please provide your website URL so I can take a closer look at your block images. If these will does not appear it should be a problem with your opacity. Maybe your images are stuck in opacity 0. This usually happens on a js error caused by plugins or customization or other external optimization tools.
Please disable all plugins except visual composer, clear cache and reset CDN files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functioning of the theme.
Peeps, many people use this feature, and most are not able to make these changes. When are the updates coming out? Something this big should be ASAP.
Hi.
It works with some Instagram ID’s, like with my personal insta, but with the original ID of my website, “circum_mundum”, it’s not working.
What is the problem?
this solution work for me, follow instruction above then use id IG (@idblabla = true, not idblabla = false)
I have interesting problem with updated files (td_instagram.php) and footer images. It doesnt work with original instagram account used on my website – it shows only header follow us on instagram, but no images bellow (instagram id zenydivky.cz). Check it on website zenydivky.cz
But when I try some other instagram account, it shows pictures fine. Tried it on other site I have where I never used original instagram account (id zenydivky.cz) and it shows pics fine there. So there must be something wrong on my site because I used account there before.
Do you cache images with td_instagram.php somewhere other than WP system cache (using Super Cache)? I mean where plugin stores images when it loads these. So I can check and clean that too.
Another idea – there is dot in instagram id (id zenydivky.cz) – could it cause that? Other instagram id I tested didnt have any dot…
  • This reply was modified 8 years by Wlk.
How can i implement this fix if i have no access to my ftp files (hosted on wordpress.com on Business Plan)
When can we expect the theme update?
Viewing 25 posts - 51 through 75 (of 103 total)
The topic ‘Social counter / and Instagram problem’ is closed to new replies.
