tagDiv Composer Problem in WordPress
When I activate tagDiv Composer Plugin, I can’t add a new posts In WordPress. It’s boken
Hello @bdsangbad!
We have also a guide with some tips why our Composer is not working properly, please check: https://forum.tagdiv.com/tagdiv-composer-not-working/
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Check some other possible factors which can interfere in our theme: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Hi Bettina,
I have tried many ways but the problem is not resolved.
My TagDiv composer is not working, I can’t edit my site with composer and can’t add new posts in WordPress. It says “The editor has encountered an unexpected error.”
What should I do?
  • This reply was modified 4 years by bdsangbad.
Hello @bdsangbad!
Please note that you need to use cloud templates, in order to edit them with the TagDiv Composer. We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
https://forum.tagdiv.com/cloud-library-templates/
https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
https://forum.tagdiv.com/cloud-library-category-templates/
