tagDiv Composer is a page and cloud builder, it can be used only for pages and cloud templates, therefore you can use it on a single post template from tagDiv cloud library to adjust the layout, but not to write the post content, for this, you need to use the WordPress editor.
You can edit the page with TD Composer in WordPress->Pages => https://www.screencast.com/t/AMOjYCA7Q7p, or in front side.
You can set a different single post template for each post if you want. Please check this guide for single post template: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
hi I’m getting an error when importing cloud templates
http://prntscr.com/ztmum5
In most cases when you get a similar message, then indeed it is a problem, most of the time the problem is from a shortcode that is not compatible with our theme, therefore after you set it with tagDiv Composer and save the page/cloud template, the next time when you try to edit it, you’ll get that error.
For this error, you can check our guide from here at point 5 -> https://forum.tagdiv.com/tagdiv-composer-not-working/
also after trying the steps from our guide you do not get any good results, you can send us via email at contact@tagdiv.com and provide WP admin link and credentials, as well as cPanel and we can investigate the problem on your website (Please make a full backup before sending the email). Include a link to this topic in the email.
No, the post content needs to be done with Gutenberg or a classic editor. You can create the post template for posts, categories, pages and so on.
Please check this video about how can create a prebuilt website from scratch https://www.youtube.com/watch?v=SoGQ0d5kIBg
You can find more details here
-> https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
-> https://forum.tagdiv.com/custom-post-type-support/
-> https://forum.tagdiv.com/introduction-cpt-acf-newspaper-theme/
