Theme changing problems
Hi there,
Approximately for 15 days, we are trying to change our theme to Newspaper theme. But We had some problems after changing. Our website is; https://muscleandfitness.com.tr/
After changing,
1. We are no longer adding any picture into our WP library, (it shows 404 error when I go to URL of the image)
2. Sometimes, the look of the website is changing randomly, and tagDiv composer plugin becomes passive without any interfere, I don’t know why.
3. Sometimes the still file is not being loaded, the home page look weird, I don’t know why.
4. The Website speed is very slow compering to the previous one.
I would be appriciate if you help us.
Thank you already.
  • This topic was modified 8 years by burakk.
First please make these adjustments in order to be sure you meet the requirements for the newspaper theme: https://forum.tagdiv.com/requirements-for-newspaper/
Then please check your cache plugin and make sure you only use wp super cache. Please check any caching provided by the host and disable it.
For page speed please use the following guides:
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
Hi there, Thank you for your help. But our host meets all the requirements that Newspaper demands. We are using W3 Total Cache for other news paper themed website which is working correctlyand It is https://www.eniyivitamin.com/
Is it possible to check our website taht has some major problems ?–> https://muscleandfitness.com.tr/
  • This reply was modified 8 years by burakk.
If you need us to investigate, you will have to provide both wp-admin and cpanel access so we can check your site and see where the errors originate from. Please contact us via email at contact@tagdiv.com and provide this information so we can investigate this properly.
