Getting complaints from my users/visitors experiencing this issue now.
I was on Bluehost for 8 years, until last year, The lack of support and the problems became to much. Server going down, It’s always the customers fault, paid outside tech to go over my site after being told repeatedly it was my site causing the issues. No problems found. Migrated site to Liquid Web and not one problem with my site since. Now that I am on Liquid web managed hosting I could not be happier, the tech support and service is outstanding, you pay a little more but well worth it for peace of mind.
Kevin P. King.
Click on Themes, Mouse over the theme, “Theme Details” will appear, click on that to expand it, bottom right Corner in Red, “Delete”
PuckWuck
Masterskg
Appreciate the advice.
Thank you B
Not an ideal fix, but will have to do until a work around or a fix comes out.
Having the same issue, tried, deactivating the plugin and reactivating it, disable, enable, clear Cache, still not showing up.
Same here, Lost the share buttons and cannot get them to show up, even after reactivating them in theme panel
Just Follow Calin’s Post at the top of the Forum !IMPORTANT NEW UPDATE Newspaper 9.7 “Please read this guide to learn about the new functionality of the new update: – https://tagdiv.com/updating-the-core-of-tagdiv-themes/” My site went down, but it is a simple fix, just follow the guidlines and you will be back up in 5 minutes.
Hey Simion I believe the issues are with my Webhost and not the theme. I am in the process of migrating the theme to the new host and will update once that is done.
Kevin
Sorry was not a 500 error, just tired last night when i wrote that. it is 504 errors and the same issues others have mentioned.
Hey Sasser Good news! The Jet pack subscription app is working again after the latest update.
Yeah looked into Mailchimp and I would exceed the Free number of emails allowed per month in one day.
Still looking though. Have tried a few but no luck so far.
Well it worked for awhile and now it is no longer working either. Will update if i can find a plugin that will work.
Hey Sasser
I tested a few this morning and found the News Letter Plugin by Web Lizar seems to integrate with the theme and have found no issues with it so far.
