I was actually referring to your own admin panel
http://www.screencast.com/t/XYJT2Z3fLHx8
Shouldn’t that be labeled with my child theme name?
We have created the child theme as per your instructions including the functions file which we just copied over from the download folder.
Things seem to be working fine but the backend admin panel is still displaying Newspaper 7.8.1 even though the child theme is selected.
Is this normal?
Hi Simion,
We’ve checked that and folder and stylesheet have same names. So i can’t be that.
The url is here
Hi folks
We had the same issue and we didn’t change anything in the CSS or hack the settings.
Just don’t forget to update your child theme with the new functions code
add_action( 'wp_enqueue_scripts', 'theme_enqueue_styles', 1001);
function theme_enqueue_styles() {
wp_enqueue_style('td-theme', get_template_directory_uri() . '/style.css', '', TD_THEME_VERSION, 'all' );
wp_enqueue_style('td-theme-child', get_stylesheet_directory_uri() . '/style.css', array('td-theme'), TD_THEME_VERSION . 'c', 'all' );
We were scratching our heads for ages until we noticed they were different from our original child theme setup.
Hope that helps people,
Hash
Ok so the best way is to use the new Mobile Editor and add the iframe through the text editor.
that seems to have worked for now. I like the new Mobile Theme so wanted to make sure a little hack could still work.
thanks
Hash
Hi Catalin,
Thanks for the reply. I did exactly what you said and then switched on my original plugins one by one. It seems to be that there was a conflict but it’s been rectified by using this method of reactivating one by one.
I do have the mobile theme switched on now and the only problem now, is that an iframe I have on one of the pages does not load. Loads fine on ipad, but on any mobile phone it simply fails to display. The link is here. Can you tell me why phones have an issue with iframes and tablets don’t?
Hi Alin,
Any update?
Cheers
Hi Alin,
Just sent an email with everything you need.
Any news on this one? I need to get the site up in a state that it was originally. The new templates don’t help and VC doesn’t seem to work when on default settings.
Hi Bogdan,
Ok now I have done a fresh install. New plugins and made all my edits to the theme settings. The CSS is loading properly but VC is still having issues.
I have default template set for home and just added new blocks to the page setup. The problem is that the blocks in rows are displating properly. None of the columns are redering properly and just spreads content across full width of row.
Have tried multiple combinations using different template selections but the rows still stretch content. Can’t figure this out. Prior to this I jsut created my page through homepage blank and everything just worked.
Maybe I’m just not understanding the new templates…can you shed any light?
Ok…I’ve done exactly the process I’m supposed to from 4.x to 6.0…and have also auto updated the site now to 6.6.
But the site is still having serious issues. The css is not loading properly I think and the Visual Composer doesn’t load any of your templates.
I really need this fixed up so I can present to the client soon.
Let me know what you need and can supply access to the site so you can see what I mean.
Just to add…this is now a clean install and was prepared to rebuild the site using any new updates the import script had carried out. So can’t understand why it won’t even display your demo content properly.
Thanks and look forward to a resolve within the next couple of days.
have had to install my backup of the site as the update wasn’t working.
The backup contains v4.6.3 – This is now working fine but would like to upgrade to latest version 6 and then update WP.
Thanks and look forwward to a resolve soon.
Hash
Hi Lucian,
Thanks for your help.
Details sent.
Cheers
Hash
I actually have a copy of the visual composer for myself for other projects. Can I use my updated copy or will that knock out your customisations?
Just trying to think how we can resolve this quickly as she can’t update or add posts right now using VC
Same result with all plugins off and refresh of cache.
Here’s a link to what she see’s. The whole text block editor is blank.
Yes well that’s exactly what I did…exported theme settings, upgraded theme, updated the VC plugin and imported theme settings back in…all VC templates are gone.
Is there something I’m missing? It’s irritating that all this work has to be done again for each page, each and every time VC plugin is updated.
Cheers
Hi Marius,
I thought I had to add something to the module template like I did for td_module_blog for style one but if it’s just CSS…that’s fine. All solved thanks.
Cheers
Hash
Hi Marius,
the link is below.
Demo site
Atelier Helsinki.
That means all the templates I have created need to be recreated right? Would be a pain to have to do that each time this theme got updates…
Hi Marius,
I’m using WPML as my multilingual plugin of choice. Be great to find a solution using this as it’s better supported.
Look forward to hearing back,
Hi Marius,
Yeh I tried that but that’s global across all languages. I want it to stay as ‘Continue’ for English but change it to Finnish if the user selects Finnish.
Sorry I should’ve been more clear…it’s a multilingual site so I can’t make global changes.
Any other options?
That’s exactly what I tried first…I now have:
function header_image_switcher() {
switch(ICL_LANGUAGE_CODE){
case 'en':
$link_to_image = 'http://demo.demofinland.org/images/top-header-en.png';
break;
case 'fi':
$link_to_image = 'http://demo.demofinland.org/images/top-header-fi.png';
break;
case 'sv':
$link_to_image = 'http://demo.demofinland.org/images/top-header-sv.png';
break;
return $link_to_image;
The Header style 1 template has:
<div class="span8 td-header-style-1">
<?php
// show the header ad spot
/* echo td_global_blocks::get_instance('td_ad_box')->render(array('spot_id' => 'header')); */
echo "<img src=" . header_image_switcher() . " />";
</div>
</div>
And all I get in the inspector is:
<img src="/"></img>
</div>
I know the code is fine and the language plugin is working great…could it be something else?
Cheers
