Slow Loading Site problem
I am creating a lot of posts on my Newspaper theme site (50 so far). And now my site load time is slowing rapidly. For each post I’ve added a featured image using the recommended size of 1068 x 713. I believe this is the problem.
http://blockchaintrailblazers.com
How can I speed up my site? What minimum size image would you suggest is best for a featured image? Are there any other suggestions you could make to speed up site? Is there a way to avoid using featured images altogether? (without them the drop-down shows blank. Can I get it to show the headline there?)
To reduce image size, can I open up “edit editor” and scale down size of image or would I need to resize an image outside the website with an image editor then re-upload?
Thx
The featured image can be bigger, for example the live theme demos use in some cases much bigger image sizes
– https://demo.tagdiv.com/newspaper/
This will however not have an impact, these original images will not be loaded in their full size on the website. Only thumbnails created from them will be shown
– https://forum.tagdiv.com/theme-thumbs/
Of course images can be further optimized. If you do not set featured images the modules in block and grids will display a default placeholder thumb. Of course your hosting plan has be ready for increased content and traffic
Suggestions for website speed are many, in this forum and also online
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://forum.tagdiv.com/topic/newspaper-theme-speedify-your-website/
– https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
