• Home
  • Showcase
    • Newspaper Showcase
    • Newsmag Showcase
  • Support
    • Newspaper Forum
    • Newsmag Forum
    • Blog
    • Documentation
      • Newspaper Documentation
      • Newsmag Documentation
      • The Theme API
    • What’s New
      • Newspaper
        • What’s New in v 11.5
        • What’s New in v 11.4.3
        • What’s New in v 11.2
        • What’s New in v 10.4
        • What’s New in v 10.3.7
        • What’s New in v 10.3.2
      • Changelog
        • Newspaper
        • Newsmag
        • tagDiv Opt-In Builder
  • Services
    • Web Development Services
    • Web Solutions & CMS Development
    • Web design & Front-end Development
    • E-Commerce Development Services
    • Page Speed Optimization Services
  • Buy Newspaper
Search
tagDiv support
  • Become a member
  • Sign in
  • Home
  • Showcase
    • Newsmag Showcase
  • Support
    • Newspaper Forum
    • Newsmag Forum
    • Blog
    • Documentation
      • The Theme API
    • What’s New
      • Newspaper
      • Changelog
        • Newspaper
        • Newsmag
  • Services
  • Buy Newspaper
Home Newspaper THEME PROBLEM
THEME PROBLEM
Kraljsin
#155396
Jan 29, 2017 at 1:03 am
Today i just lose logo on wesite also on a mobile theme, than main banners , backgrounds etc , everything it was just empty i also saw that i need to put activation code on dashboard for theme which i put before when u bought theme.. what can be problem?
is it way to return that jow it was?
thanks
Catalin
#155597
Jan 30, 2017 at 2:39 pm
Hello Kraljsin,
It is strange…sorry! Please notice that our theme update does not influence your databases and you should not have to happen to you so. If you are using some untested plugins, you should try to disable all of them, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins. It is possible that your untested plugins used by you to interact with the theme core files and cause these unknown issues.
Kraljsin
#155609
Jan 30, 2017 at 2:53 pm
i have plugins but all ok,not untested,but i lose everything from theme panel like its new.. and i need to put licence code again
is it way to backap data if something happend again?
Bogdan B.
#155786
Jan 31, 2017 at 11:48 am
Creating aback-up is highly recommended. Please use this guide and create regular back-us to your install:
https://codex.wordpress.org/WordPress_Backups
Kraljsin
#163377
Mar 20, 2017 at 9:17 pm
Dear today second time i lose again all banners main logo, all ads
and i got message that my theme is not regitered and i must to put again licence code and to put again everything from start
whats problm
start to be very disapointed
simchris
#163380
Mar 20, 2017 at 9:26 pm
Seems like you don’t have your site very well configured if you keep breaking it.
See my comment on your other post on this topic.
Site can’t “suddenly” break unless you update it, change it, your host changes system, or you get hacked.
Meranda Devan
#163395
Mar 20, 2017 at 10:47 pm
Does this theme allow you to update it from the panel? I don’t want to re-install a theme every time there is an update…. Just getting the theme on to my server was a very involved process for us.
  • This reply was modified 9 years by Meranda Devan.
simchris
#163402
Mar 20, 2017 at 11:41 pm
Meranda Devan
you likely want to start your own topic.
You can update the theme from the panel, but you need to download the theme zip from Themeforest, then install that zip by uploading from your hard drive.
Alternately, it’s wise to learn how to FTP, as this is the best method to upload theme update while deleting old folder, making backups of images, folders, etc., and uploading any plugins included with theme you actually use.
Kraljsin
#163591
Mar 21, 2017 at 6:10 pm
today was theme update after update i cant see any pictures on my web page .. do u know what can be problem? i use enavto market automatic plugin
simchris
#163603
Mar 21, 2017 at 7:32 pm
Don’t use the Envato updater as it never works right on many server setups due to permission/ownership problems.
FTP is best way, and only way if you keep having problems.
Kraljsin
#163802
Mar 22, 2017 at 1:50 pm
yesterday i had again same problem theme is broken like reset and i need still again to work everything from start
Bogdan B.
#163874
Mar 22, 2017 at 5:01 pm
If you cannot see the images, it could be a plugin conflict and not a theme update issue. You probably have a js error in your browser console that breaks the lazyload animation. Try to find which one of your plugins causes the issue and remove/replace it. This is done by disabling all plugins at once, clearing the cache and resetting/purgins cdn files if you use it. Then re-activate the plugins one by one testing your site after each one to see which one causes the images to break
Or it could not be a plugin at all and it could be a custom modification you made or your child theme that need updating as well. The child theme is not update proof. Try to switch to the main theme to test it out.
I hope this helps.
Kraljsin
#164667
Mar 27, 2017 at 5:44 pm
WP experts told me that i have big problem with this theme
this theme make 1400 queeries per 1 visits to base which is abnormal
how it is possible?
Bogdan B.
#164798
Mar 28, 2017 at 10:10 am
The requests depend on the number of visitors you have and on the number of complex elements on your site. If you have lots of blocks with pagination and ajax filters, the requests could go up. Please make sure you use a caching plugin : https://forum.tagdiv.com/cache-plugin-install-and-configure/ and a cdn server is also recommended: https://forum.tagdiv.com/cloudflare-cdn/
Kraljsin
#164880
Mar 28, 2017 at 1:42 pm
Daer Bogdan,
i have all of that and my wp administrators told me they never saw that some theme made so many request to the data base. They did analise and per one visitor is 1400 queries to base and normal is from 50 to 200..its too much and when we put one picture also theme made 10 more pictures..
3 times my theme broken i lose all data baners and everything i must put all from the start
and now some function stop to work for example on some sliders on main page not work u can go left or right.. then u cant put word in searh place for searching and some more…
what can be problem then
Simion C.
#164922
Mar 28, 2017 at 4:29 pm
Basically the theme has these requirements as specified here – https://forum.tagdiv.com/requirements-for-newspaper/ in order to get the best results. Some further modifications are recommended to be made according to this guide – https://forum.tagdiv.com/system-status-parameters-guide/
If all these simple conditions are met it is recommended to use a caching plugin and the CDN as mentioned in the previous reply. Also a tutorial about improving page loading speed is available here – https://forum.tagdiv.com/how-to-make-the-site-faster/ meant to help you optimize website speed.
Some of these recommendation are not mandatory and a website can work properly without them. Please note that some plugins can have a negative effect on websites and cause unexpected results, so you should test this using only the latest version of the plugins, provided in the theme package.
Thank you for understanding!
Kraljsin
#165305
Mar 30, 2017 at 3:45 pm
And what can be problem than any slider not work its just static and if u want to see pictures sighns < left or > rights not work anyhere on site and even part where is searching u cant put any keyword for searching? how to resolve that
Simion C.
#165409
Mar 31, 2017 at 9:36 am
I suggest you try to make a clean theme install – https://forum.tagdiv.com/install-via-ftp/ and use only the plugins bundled in the theme package. This should fix all the problems you are having at the moment. If after doing a reinstall the issues are still present, please send us an email at contact@tagdiv.com and provide admin login information, so we can take a look. Also paste a link to this topic for identification purposes.
Kraljsin
#165462
Mar 31, 2017 at 2:13 pm
Today i got tgis from my server:
We see that you have not yet moved your website, and the extreme resource usage continues.
Please be advised that if this is not resolved ASAP, we will need to close down your website.
PS: the number of files in your website has now grown from 658 thousand to 2.48 million. Your software is misbehaving extremely badly, and it prevents us from taking any backups.
how it is possible from 658 thousand to 2.48 million?
Simion C.
#165478
Mar 31, 2017 at 4:03 pm
I do not know what could go wrong if you have made a fresh theme install and used only the plugins provided in the theme package, and the problem is still there. Maybe this is not theme related, because we have not had any complaints with this issue. As I suggested please send us email at contact@tagdiv.com and admin login information so we can take a look and see if this is theme related.
adnan
#165479
Mar 31, 2017 at 4:05 pm
With 32 Plugins on my site the home page (lots of blocks) 110 queries per visit and in a single post 80 queries per visit, So i thing not a theme problem.
Kraljsin
#165514
Mar 31, 2017 at 8:13 pm
i have 14 plugins but theme made 1500 queries per 1 visit
Viewing 22 posts - 1 through 22 (of 22 total)
Kraljsin
Support Hours (GMT+2)
Monday - Friday:
8:00 AM - 17:00 PM
Documentation
  • Newspaper
  • Newsmag
Facebook Instagram Twitter Youtube
Welcome to the Community! This is our main Support Center and, also the place where you can make new friends, people just as passionate about websites as you are. Don’t hesitate to ask for help as we are here for you. Thank you for buying our products!
Contact us: contact@tagdiv.com
  • Home
  • Blog
  • Forums
  • About us
  • Support policy
  • Privacy Policy
© tagdiv.com | Proudly made with by tagDiv. All rights reserved
We use cookies on our website to give you the most relevant experience by remembering your preferences and repeat visits. By clicking “Accept All”, you consent to the use of ALL the cookies. However, you may visit "Cookie Settings" to provide a controlled consent.
Cookie SettingsAccept All
Manage consent
Privacy Overview
This website uses cookies to improve your experience while you navigate through the website. Out of these, the cookies that are categorized as necessary are stored on your browser as they are essential for the working of basic functionalities of the website. We also use third-party cookies that help us analyze and understand how you use this website. These cookies will be stored in your browser only with your consent. You also have the option to opt-out of these cookies. But opting out of some of these cookies may affect your browsing experience.
Necessary
Always Enabled
Necessary cookies are absolutely essential for the website to function properly. These cookies ensure basic functionalities and security features of the website, anonymously.
CookieDurationDescription
cookielawinfo-checkbox-advertisement1 yearThe cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Advertisement".
cookielawinfo-checkbox-analytics11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Analytics".
cookielawinfo-checkbox-functional11 monthsThe cookie is set by GDPR cookie consent to record the user consent for the cookies in the category "Functional".
cookielawinfo-checkbox-necessary11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookies is used to store the user consent for the cookies in the category "Necessary".
cookielawinfo-checkbox-others11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Other.
cookielawinfo-checkbox-performance11 monthsThis cookie is set by GDPR Cookie Consent plugin. The cookie is used to store the user consent for the cookies in the category "Performance".
viewed_cookie_policy11 monthsThe cookie is set by the GDPR Cookie Consent plugin and is used to store whether or not user has consented to the use of cookies. It does not store any personal data.
Functional
Functional cookies help to perform certain functionalities like sharing the content of the website on social media platforms, collect feedbacks, and other third-party features.
Performance
Performance cookies are used to understand and analyze the key performance indexes of the website which helps in delivering a better user experience for the visitors.
Analytics
Analytical cookies are used to understand how visitors interact with the website. These cookies help provide information on metrics the number of visitors, bounce rate, traffic source, etc.
_ga2 yearsThis cookie is installed by Google Analytics. The cookie is used to calculate visitor, session, campaign data and keep track of site usage for the site's analytics report. The cookies store information anonymously and assign a randomly generated number to identify unique visitors.
_gat_gtag_UA_43963494_11 minuteThis cookie is set by Google and is used to distinguish users.
_gid1 dayThis cookie is installed by Google Analytics. The cookie is used to store information of how visitors use a website and helps in creating an analytics report of how the website is doing. The data collected including the number visitors, the source where they have come from, and the pages visted in an anonymous form.
Advertisement
Advertisement cookies are used to provide visitors with relevant ads and marketing campaigns. These cookies track visitors across websites and collect information to provide customized ads.
IDE1 year 24 daysUsed by Google DoubleClick and stores information about how the user uses the website and any other advertisement before visiting the website. This is used to present users with ads that are relevant to them according to the user profile.
test_cookie15 minutesThis cookie is set by doubleclick.net. The purpose of the cookie is to determine if the user's browser supports cookies.
VISITOR_INFO1_LIVE5 months 27 daysThis cookie is set by Youtube. Used to track the information of the embedded YouTube videos on a website.
YSCsessionThis cookies is set by Youtube and is used to track the views of embedded videos.
Others
Other uncategorized cookies are those that are being analyzed and have not been classified into a category as yet.
CONSENT16 years 5 months 26 days 13 hours 25 minutesNo description
yt-remote-connected-devicesneverThis cookies is set by Youtube and stores the user's video player preferences using embedded YouTube video.
yt-remote-device-idneverThis cookies is set by Youtube and stores the user's video player preferences using embedded YouTube video.
SAVE & ACCEPT
Powered by CookieYes Logo
