HOW TO ARRANGE POSTS IN 3 COLUMNS OF 10 POSTS OR 12 POSTS IN EACH COLUMN
I AM POSTING JOB ALERTS in my website and i want to know which template is more suited for more posts in less loading time and at the same time i want to arrange posts in 3 columns with 10 posts each?also mobile version is not showing the images and amp version doesn’t show many ads .
What are these alerts exactly? Are they posts? You can split the rows in the composer into columns https://prnt.sc/ud0wwg
You can stretch the rows to have a wider layout https://prnt.sc/ud0xfj
You can use inner rows inside rows, to have even more columns if needed https://prnt.sc/ud0xyr
Then you can enter the blocks you want, check the cloud library as well, maybe you find one that you can use for this task https://cloud.tagdiv.com/#/load/Blocks There are quite many designs in the cloud library.
Each block has a post limit, you can limit the posts as needed https://prnt.sc/ud0za1
The guide is here https://forum.tagdiv.com/flex-block-settings-guide/
i tryed to install these templates as you have showed in images,but not able to install and it is showing it is installing ,but is very slow and not even installing. My site is http://www.techjobs360.com and i want only the posts to be arranged with featuredimage of the posts.i wanted 3 columns or 4 columns of posts with 10 rows (currently it is 2 columns with around 10rows)in desktop and since i am using amp version in mobile i just want maximum posts to be loaded one by one with respective featured images also. now the images are also not loading in mobile , itryed various settings .because of this reason website is getting low traffic from google discover feed etc. i request you to give good solution .thank you.
Hi arunbabu,
So if I understand correctly, you’ll like to have 3-4 columns with 10 posts each one, and from what I can see you are using now as homepage the blog, for this you can achieve 3 column by setting in theme panel > templates settings > blog no sidebar and choose a layout that has 2 columns (when is set no sidebar it will be add another column), after that in Settings > Reading set the number of posts you’ll like to display -> https://i.imgur.com/CWaVSXr.png the results will be like this -> https://i.imgur.com/Q47je31.png
Also to see the featured image on mobile devices you need to enable the small thumbs from theme panel -> https://i.imgur.com/ZiFXCGw.png -> https://i.imgur.com/85C1GyE.png also you can try the mobile theme plugin -> https://forum.tagdiv.com/the-mobile-theme/
to tagDiv
hi ,
I was able to bring it into 3 columns .but there is a side bar which pops even after switching off all the sidebars.also i want to footer but since i have loaded some template from element (tag -di page builder i have not able to set footer area. also kindly highlight how can i arrange categories in footer (all the different categories).
and also no ads are not getting displayed in amp version (home page ) of website .please suggest which is the besr version of mobile theme to install it keeping in mind of amp audience.
The footer can be set from theme panel, you can set a page as footer, you can chose a standard footer or a cloud footer -> https://forum.tagdiv.com/footer-templates/
To display ads on amp version we recommend to use the mobile theme plugin with one of these options -> https://i.imgur.com/pWsbjoW.png also the ads set for mobile theme template will be display in amp version too.
If you are referring to this sidebar -> https://i.imgur.com/Mf5bgnI.png you can enable and disable it from theme panel -> https://i.imgur.com/w84ZuDK.png -> https://forum.tagdiv.com/more-articles-box/
Hope this will help you!
i added footer menu and kept in the place, but i believe it is displayed in amp version of the footer and is not appearing in desktop .also i am getting message like this when i am adding the widgets.”Your theme has 5 widget areas, but this particular page doesn’t display them.You can navigate to other pages on your site while using the Customizer to view and edit the widgets displayed on those pages.””
also my website is loading in amp version but no featured image is loading in amp version (but is loading in mobile version)also i want to display ads after every 3 or 4 posts but only 3 ads are appearing in amp version not utilising the posts. since i am showing almost 36 posts in home page i want to show atleast one ad after 4 or 5 posts.kindly help me to get to website organised
To remove that notice, please make sure that you set the theme settings as in our guide -> https://forum.tagdiv.com/requirements-for-newspaper/ -> https://i.imgur.com/9Tt8e6v.png
Also if you are using the mobile theme plugin template for amp please make sure that the mobile theme thumbs are enable in theme panel -> https://i.imgur.com/AgkQUFa.png
Unfortunately, the theme does not have an option to display the ads on mobile/amp after each n posts, it can be set only once -> https://i.imgur.com/p1mEbzy.png
hi ,
i dont know why footer is coming in amp version and mobile version ,but not able to set in desktop .i just want to MAKE IT SAME ACROSS desktop and mobile. Also which settings i should for amp version which enables my posts to appear in google discover and also the size of the image .can i use a third party ads plugin to enable to ads in amp and mobile version for multiple ads.
Hi lazyload ,
For footer you can set a standard footer, a page footer or a cloud footer.
Now I think that you have set an empty page -> https://i.imgur.com/197iK7P.png you can check more in our documentation from here -> https://forum.tagdiv.com/footer-templates/
Also for mobile and amp ads you can use these fields from theme panel> mobile theme -> https://i.imgur.com/K0wtrDV.png you can use plugins too, unfortunately I do not know one that is the best with our theme.
