Need help on several things
The theme Full Big grids or Big grids will display posts sorted by the option you choose, in the grid filter tab
– https://www.screencast.com/t/jvNomLy5J
The posts displayed will change based on that sorting. For example a Latest post sort order, will always display posts as soon as published. You could use the Revolution slider as well, on pages
– https://forum.tagdiv.com/how-to-install-revolution-slider-v5/
– https://forum.tagdiv.com/import-revolution-sliders-on-demos/
I tried what you said, but which button or place should I click or go to choose 7 articles or 10 articles in rotation? I need them to slide every 10 secs, and 10 articles in rotation.
Please provide more information about what you tried, so we can avoid misunderstandings. The default grids will not slide, the Big grid slide or slider can slide posts
– https://demo.tagdiv.com/newspaper/big-grid-slide/
– https://demo.tagdiv.com/newspaper/ios-slider/
– https://www.screencast.com/t/t7ipLCHZ9I
You cannot set a fixed number of posts in rotation in normal grids, unless manually inserting those post IDs in the filter tab
– https://www.screencast.com/t/247skBpw6
A big grid slide has options for limiting the post number however, and an autoplay setting
– https://www.screencast.com/t/LEYPko2l
Thanks for your explanation. I think I am looking for slide on this one instead. Is it possible if I can manually inserting those post IDS in the filter tab such as , all the ones with selection of “featured”? If there are 20 or 80 articles with featured, can I limit down to only 5 or 10 articles for slide ( the newest ones )? Can I set the timer so it will slide to next article within 5~10 secs?
Once again, what exactly is post ids? Is it its URL link? or there is an ID assigned for each new article on the website as a string of numbers?
I still haven’t head a clue on how many words/letters should I choose for Chinese? Please take a look at my front page and see many of the articles are not showing its complete title. Do you have any idea what numbers should that be? The bigger the better? In that case, should I choose 100 for letter for all articles,just to be safe that it can display the complete title ? http://jazko.com/
Also, with plug-in WP Super Cache, what is the best setting to choose? Is it normal level 2 or …level 4? I sometime need to wait a few hours before I can see the changes I made in setting. Where should I go to change the setting, so each adjustment I applied on setting can be showed or displayed when I refresh the website? right away or within seconds not hours.
In Reading, I can choose Front page. What is Post page for? Do I need to choose that one as well? For pagination, I want each page to show 10 articles only, and on the bottom will show 1 2 3…more , how can I do that? I have pagination on my front page now with sign <> , not showing numbers as the reader can choose page 1 or page 3…etc
How can I make them the way I want it to be?
On the category page , http://jazko.com/category/travel/ , I have side bar customized. I don’t want them anymore, but forgot how I can change it back to default. Can you please point them out for me again? Thank you.
Last question, is there a plug-in that can allow me to post any new article on my website and also automatically showing them on social media such as FB/instagram? Any recommendation?
I know some of these questions may be related to the previous questions, but a lot of information to digest, and appreciate for your patience and guidelines to help out.
You can include posts in the Featured category
– https://forum.tagdiv.com/featured-posts-2/
Then choose the Featured category in the slide filter settings, and sort by Latest
– https://www.screencast.com/t/cjaN2O4V
In this situation the slide will display the latest posts added to the Featured category. A limit of posts can be set as well as an autoplay interval
– https://www.screencast.com/t/XouPGmR1
So now the slide will display for example 5 latest posts from the chosen category, changing every 5 seconds.
The excerpt in this case should be set to letters, maybe choose the same value for all modules. The post titles will not be the same for all posts, experiment with different values for the blocks you use, until you find a perfect solution.
Regarding the cache configuration there is a guide
Some settings might have changed, but most are the same
– https://www.screencast.com/t/viT3UUna
We will update the tutorial as soon as possible, taking in account the changes in the cache plugins panels.
The front page will be used to display the posts, you will not be needing that option to use a different page. The “Blog pages show at most” setting controls the number of posts in the Latest articles section (if there is no value set manually – https://www.screencast.com/t/3Io9tIeZhU2), and on category pages loop
– https://www.screencast.com/t/VN0sogW6LNS
– https://www.screencast.com/t/W8vNqqmA1RFs
A sidebar can be set or removed for each category, in the Per category settings. The actual sidebar content can be customized in Appearance->Widgets
– https://www.screencast.com/t/DatBdFk8j
There could be such plugins, but we cannot make any recommendations. You can search for and try out a few plugins that have options like this. The post can be shared but manually, not automatically
– https://forum.tagdiv.com/sharing/
Please let us know if you have further questions, we will try to help you as soon as possible.
As for permalink, I choose custom structure with http://www.jazko.com/%category%/%postname%/
This is giving me the result I like, however, I don’t think SEO sees it that way? Reason I am saying this is as below:
As I try to find keyword for this topic ” brand 999.9″, here is the result we get.
jazko.com › 流行趨勢 › 眼鏡潮流 <- what I found on search engine
http://jazko.com/fashion/frame/japan-9999/ <- what I expect to see on search engine
Is there anything I can do about it? The link shows up the way I want it to be. Just not sure why SEO or search engine didn’t pick up the exact word we put there.
Also, is there any plug-in that you’d recommend to use if we want to translate the whole page from English to Chinese? or Chinese to English? Is there a useful plug-in you know works with Newspaper that can do multi-language?
I also got another question about SEO. What should I do when I was asked to upload this:
Verify your ownership of http://jazko.com/. Learn more.
Recommended method Alternate methods
Recommended: HTML file upload
Upload an HTML file to your site.
1. Download this HTML verification file. [google62844fad1f3142c5.html]
2. Upload the file to http://jazko.com/
3. Confirm successful upload by visiting http://jazko.com/google62844fad1f3142c5.html in your browser.
4. Click Verify below.
To stay verified, don’t remove the HTML file, even after verification succeeds.
And, something about XML Site map?
I received this email notifying me there is an update available. What should I do to get this updated? Is there a button says update? or do I need to donwload the whole package and replace it? Please walk me through step by step as I am very new at this.
I could ‘t say exactly why the search results are displayed like that by Google. Maybe you can find more similar cases online. It could have something to do with the website language.
The Yoast SEO plugin has to be used for SEO optimization, the theme does not have any options or settings in this matter.
For translation you could try the qTranslate plugin. The theme is compatible with WPML also. Or make tests with other plugins as well
– http://www.wpbeginner.com/showcase/9-best-translation-plugins-for-wordpress-websites/
I believe that verification code has to be entered in the theme header file, between the head tags
– https://www.screencast.com/t/3ORNutEVslq
There are multiple methods to update the theme
– https://forum.tagdiv.com/how-to-update-the-theme-2/
The new updates simply updates the Visual composer and Revolutions slider plugins. Also some modifications were made to a couple of theme files
– https://forum.tagdiv.com/topic/what-exactly-is-new-in-the-newspaper-8-1-version/
As for sitemap.xml , what should I do about it? or it’s already there? Where should I go to find one? I’d like to register my website on search engines, but I am not sure if I should generate one from this website https://www.xml-sitemaps.com/ , or it is already existed here with Newspaper Themepanel.
Please advise and explain me more details with screenshots as if possible, if it’s hidden somewhere in my computer or files. Thank you.
In addition, I checked YOAST SEO plugin, and it said as below:
XML Sitemap
Generated by YoastSEO, this is an XML Sitemap, meant for consumption by search engines.
You can find more information about XML sitemaps on sitemaps.org.
This XML Sitemap Index file contains 4 sitemaps.
Sitemap Last Modified
http://jazko.com/post-sitemap.xml 2017-10-22 10:35 +08:00
http://jazko.com/page-sitemap.xml 2017-10-17 21:57 +08:00
http://jazko.com/category-sitemap.xml 2017-10-22 10:35 +08:00
http://jazko.com/post_tag-sitemap.xml 2017-10-22 10:35 +08:00
My question is, how many xml site maps should I register? the more the better? In general, how many should search engines to look at , in order to maximize or optimize the visibility of this website to the world? Just a general idea, if you are not certain of this as the rules changes everyday…i heard? not sure if it’s true.
Sorry, one more question. Many search engines only leave me one line for xml sitemap, so which one should i fill in?
One more questions. As I am creating a business email account, it asks me to provide ownership of the website, where should I go to look up this info:
Verify by adding a meta tag
Use this method if you can edit jazko.com’s homepage HTML. You’ll add a meta tag containing a verification code to your website. This won’t affect your website or email.
Copy and paste the meta tag into your home page at http://jazko.com. Place the meta tag in the <head> section and before the <body> section of your homepage.
I know this is an open place, so if you should not tell me the answer in public, please just tell me where to look them up or send me an email.
Sorry, I have one more question. It is irrelevant to my previous question.
As for Page setting, when I edit them with TD composer, let’s say if I added 3 columns, and changed my mind that I want to reduce them to 2 columns only. How can I delete the column that is added already. I could not find the delete sign anywhere. Please understand I am saying to remove that column entirely, not different setting for it. (Not the case that I choose block or full grid and I can delete them and choose some other format as I wish, I want it gone entirely as it’s just an unnecessary column for me after it’s added)
I am asking this, because I want to add a few more columns to my front page now, but I may want to remove them in a couple of months/years. I do not wish to delete the whole page and make a new one for it. That is why I want to know if there is a way to remove them easily without going so much trouble for them.
Please follow these topics to help you with the website sitemap configuration and for a better understanding, using the Yoast SEO plugin
– https://kb.yoast.com/kb/enable-xml-sitemaps-in-the-wordpress-seo-plugin/
– https://yoast.com/what-is-an-xml-sitemap-and-why-should-you-have-one/
– https://kb.yoast.com/kb/how-to-customize-the-sitemap-index/
– https://kb.yoast.com/kb/submit-sitemap-search-engines/
According to the instructions that verification code needs to be entered as mentioned before, in the header.php file found in the main theme folder. Place the code as provided in that file, between the <head> tags
The page layout can only be created using the available row layouts
– https://www.screencast.com/t/sMgqlkFL
If you have a 1/3 + 1/3 + 1/3 row layout you can simply chnage it to a 2/3 + 1/3 layout and leave the 1/3 column empty
– https://www.screencast.com/t/2JP8W45N0t
The space will be reserved, the columns cannot be removed. Only the rows can be removed
– https://www.screencast.com/t/ljeDqJwbXjdH
Content inside columns can be removed if it is not needed anymore, but columns cannot be removed.
Thanks for answering those questions earlier. I’d like to ask for Footer or anywhere on the website, is there an option for me to choose which social media I’d like to use or put up with. I don’t want a package of everything as I won’t be using all those. If I want to narrow them down to Facebook/Instagram/WeChat(Chinese)/Weibo(Chinese)/Youtube , is there a place where I can choose this?
Another question is, if I want to embed a video from Youtube, and I know where to copy the code, with Newspaper Theme, can I switch to Text in the article and just copy and paste that embedded code, and then it’d embed a youtube video in that article? It works for other wordpress site before, but when I tried them this morning, it works before I updated it ( run the preview and its working), however, it kinda messed up the whole thing after I hit updated.
I wonder if the only safe way to embed or to show a video (not a link), but a screen that can hit and play video in the article would be choosing the function and key your team created? Please help me out here.
I’d like to use google analytics for my website as well. Now, I have tracking ID, but I am not sure where to put them at. Can you please guide me through? Thank you again.
I think i made a lot of changes with setting today, and my front page is all messed up now. Is there a way that I can jump back to 24 hours ago with all setting? So, everything would look like 24 hours or even 10 hours ago?
Please advise. Thanks for your help!
I would like to point out the “messed up” part. It is the footer become super long. If I read from mobile, it looks fine with 4 main categories: gourmet/travel/fashion/outdoor with 10 posts each.
However, when I run them on PC through google chrome or firefox, it looks so bizzard.
Please help to check out http://www.jazko.com and tell me if there is anywhere I can go to make this look normal again.
My front page setting would be slide on top , then four categories with block 16. That is all, with ads on top. Not a complicated setting.
This is really urgent for me. I’d appreciate if you can get back to me today on this.
If possible, can you please also explain me what went wrong? Could it be some of the plug-in I downloaded to have this issue?
Do you need access to my website in order to get this fixed?
Once again, I’d really appreciate if you can let me know by the end of today. Thank you.
I’d like to point out one thing is different from my previous setting too.
All the images are set to be rectangular shape, not square. In other word, the width is not same as length.
However, if you take a look at this page, the setting for articles are now all looking in square shape. How can I fix this? It was not like this the day before.
http://jazko.com/category/fashion/
The socials displayed in the footer will be the ones you enter in Theme panel->Social Networks
– https://www.screencast.com/t/uPvvykgGhUK
For embedding videos all there needs to be done is to paste the video link in the post content. More information here
– http://www.wpbeginner.com/beginners-guide/how-to-easily-embed-videos-in-wordpress-blog-posts/
– https://codex.wordpress.org/Embeds
You can also create playlist in the post content (only YouTube and Vimeo)
– https://forum.tagdiv.com/video-playlist-2/
There is a section in the theme panel specially created for Google analytics, enter the code there, exactly as provided
– https://www.screencast.com/t/jUk2h10OkxMa
On the bottom of the page edit screen, you should have revisions, you could load a previous revision. That would revert the page as it was at that time
– https://codex.wordpress.org/Revisions
I don’t see anything wrong with the footer on the website
– https://www.screencast.com/t/orMGYatgBh
That is how the footer displays. There are multiple footer templates to choose from, maybe you changed the template used
– https://forum.tagdiv.com/footer-templates/
The footer will become boxed (not full width) if a background image or color is set
– https://forum.tagdiv.com/background-introduction/
That is a category page, the module that is used to display the posts can be changed in the theme panel, per category or in general
– https://www.screencast.com/t/dwJfeOf2
– https://forum.tagdiv.com/how-category-settings-work/
The footer problem is solved. I think what happened is when I entered letter 120 for excerpts, then something about my display got messed up. Not sure if that is correct.
However, it got fixed after I changed a few setting a few hours after.
Therefore, can I please ask how to refresh my page right away and see the new changes? Would it be my cache setting? If so, which one should I choose to make sure the change happens and shows immediately?
Last question is, when I try to submit sitemap to search engines, I really have no idea which ones to choose. Can you please give me any idea? I mean is there a XML Sitemap (main) to use? When I go to Yoast SEO, it generates 4, and I have no idea which to submit.
Please advise if you know. Thank you once again!
Other than sitemap, Google also says…
We do not detect any structured data on your site.
Structured data helps Google understand the content on your site, which can be used to display rich snippets in search results.
You provide structured data by adding HTML markup to your site’s pages.
Read more about rich snippets.
Visit schema.org – an industry-supported collection of schemas for structured data markup.
Please advise where can I find or build the structured data that can be seen by search engines as google/bing…etc
Hello again!
My apology for sending 2~3 emails a day, sometime 4 seeking for your help.
However, this is all brand new to me, and I got another huge question from Bing.
Can you please tell me what to do? I don’t even know where to go to operate these commends.
Verify ownership for: jazko.com
Option 1: Place an XML file on your web server
Download BingSiteAuth.xml
Upload the file to http://jazko.com/BingSiteAuth.xml
Confirm successful upload by visiting http://jazko.com/BingSiteAuth.xml in your browser
Click the verify button below
Option 2: Copy and paste a <meta> tag in your default webpage
You can add a <meta> tag containing the authentication code to the <head> section of your default webpage.
<meta name=”msvalidate.01″ content=”23D518B6F43448754E67E202E536BA23″ />
An example:
<html>
<head>
<title>Your SEO optimized title</title>
</head>
<body>
page contents
</body>
</html>
Option 3: Add CNAME record to DNS
Add CNAME (alias) record with name c89e928f523800c2a4cd246e7c22896b and value verify.bing.com.
So your DNS provider will resolve host c89e928f523800c2a4cd246e7c22896b.jazko.com to verify.bing.com.
How to add a CNAME record to:
Viewing 25 posts - 26 through 50 (of 77 total)
